Search Forums | Classifieds (136) | Skins | Language
gas blowoff valve?
teach84
Posted 2/10/2025 19:55 (#11098252 - in reply to #11097610)
Subject: RE: gas blowoff valve?
west-byGod-Pa.
There is a set-up one can get: consists of a 4" pie 4 feet tall, with a grate inside- about midway up. It must be plumbed into the gas line & requires exterior piping & valves to set up by-pass while servicing the dryer. How it works, one takes a cap off the top & drops white "calcium" tablets in top half. Gas from well comes in the bottom & flows up thru tablets which strip moisture away.
In our case , once a year we close/open bypass valves for service: open a bottom valve to drain fluid, & add tablets to top. Complicated to get valves & plumbing set up correctly, but it works. I need to take photos so I can post them. Pictures help a lot
