SD | Went and looked at a JD 9300 4WD tractor coming up for sale with the 12.5L engine. It has a little over 4,000 hours and seems to be very well maintained. Upon start-up it puffs out a little white smoke and if you rev up the engine from idle it briefly puffs out some white smoke then clears up. Is this something to worry about or a watch out? Anything simple to check for? I appreciate any advice on what this might be. | |
